by: gmikes
#23928
Hello people,
Gucce hd92 web cam won't work.
Can somebody help me to figure out what kind of problem it can be?
I plug the cam in usb, but there are no reaction, and the system it self do not see that cam...
Thanks for any help.
#23932
Run these commands in Terminal then run the installer attached below then reboot,
rm -rf /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin
rm -rf /System/Library/SystemProfiler/SPUSBReporter.spreporter
(679.48 KiB) Downloaded 35 times
by: gmikes
#23955
So, report... The camera seems to work only in FaceTime, but not any time after restart the app. And till Usb fixing I had no system lags, but now it seems to work little bit slower.. or better say little laggy :(
#23975
What happens if you remove the webcam and plug it in again? My one seems to be working fine.
by: pirata129
#24136
Thanks to Shanee..
PhotoBoot and FaceTime works again with my webcam..great work,Shanee!
I have the same CPU and Motherboards.
Great Forum!
Shanee, Skype works too... :thumbup: :wave:
Shaneee liked this
by: gmikes
#24777
Shaneee wrote:What happens if you remove the webcam and plug it in again? My one seems to be working fine.
no metter what usb I using, the same thing... won't work :(
by: Nado
#42762
Shaneee wrote: Thu Jul 20, 2017 5:36 pm Run these commands in Terminal then run the installer attached below then reboot,
I have just installed Skype today and realized that it doesn't play well with the amd osx. To start it showed up on skype pref as USB webcam, I could see the video working in test - but when I tried to do a video call the webcam light turns off and dead. So I tried this in terminal and now it doesnt even detect the usb webcam which is a Logitech C270 HD Webcam - see attachment
#42764
System specs?
by: Nado
#42771
Shaneee wrote:System specs?
CPU: AMD Ryzen 5 - 3,800 GHz
GPU: Radeon RX 570 - 4 Gig
MBO: MSI B350M PRO-VDH
RAM: 4 x 8GB- 2400 MHz DDR4
Should be added to my signature now. - i tried the scripts but the zip is like 0kb
#42779
Nado wrote: Thu Sep 20, 2018 9:35 pm
Make sure you've got the original USB files and haven't swapped them out for any fixes then use the native USB fix here, viewtopic.php?f=24&t=4986
