by: staggeredsix
#23434
Hey folks,
After smashing my head off the wall for a while it looks like I found a fix.
Using Fake PCIID and the Small Tree kexts I was able to get the darn thing working.
Attached is the three kexts needed. As always, back things up before tweaking. Hopefully this helps someone.
(84.34 KiB) Downloaded 407 times
by: Dark Diver
#25653
I use SmallTreeIntel82576.kext from there:
http://www.insanelymac.com/forum/topic/324392-ryzen-clover-installation-guide-macos-sierra/page-23#entry2460269
It's just SmallTreeIntel82576.kext, but patched to support Intel i211. There is no need for other kexts, just install this one. Works for me good. Earlier I used current AppleIGB, but had different problems with it.
Sundhar88, Shaneee liked this
by: GiaSen
#51401
staggeredsix wrote: Tue Jul 11, 2017 8:44 pm Attached is the three kexts needed. As always, back things up before tweaking. Hopefully this helps someone.
Help me looks like that file is corrupted
I can't find a kext for my i211-at on crosshair hero vi
