#21251
Ive made a thread recently amd fixed that problem.. Now i can boot into installer but stuck at 15 minutes remaining when installing.. Also tried niresh sierra but after putting the boot flag for amd kernel just reboots, but i dont thing you can help me with that
#21252
M4rM0rKuch3N wrote:Ive made a thread recently amd fixed that problem.. Now i can boot into installer but stuck at 15 minutes remaining when installing.. Also tried niresh sierra but after putting the boot flag for amd kernel just reboots, but i dont thing you can help me with that
Your installer has slept, Use a 3.0 port or keep your mouse moving during installation process. I'm sure the problem will fix.
#21253
I dont have a USb3.0 Port and the mouse is moving fine ist not frozen ist just stuck at 15mins remaining
#21290
DutchMan_1990 wrote:Use USB 2.0 but keep your mouse moving through out the process, it seems like installation is ongoing,but apparently the installer has slept.
So you mean the Installation is still going but the bar which Shows the process is not moving further ?
