by: Mauro Borrazzo
#18630
Hello!
I've installed Mac OS Sierra on my Toshiba Satellite C855-233 with an AMD Rateon HD 7610m graphic card.
On "About this Mac" he tells me the model of the graphic card but with 4MB:
Graphic: AMD Radeon HD 7500/7600 4 MB
Do I need to install a kext?
by: Mauro Borrazzo
#18631
Mauro Borrazzo wrote: Wed Apr 26, 2017 9:19 pm Hello!
Sorry for my English but I'm Italian :mrgreen:
by: sesialex
#18640
You need to inject fake id with clover configurator. Find card from 7000 series with same chipset and use fake id to add it. Go to Clover Configurator into fake ID ATI you need to add your fake id, you make fake id with 0xXXXX1002(big XXXX is your card fake id like... 6810 so full id is 0x68101002), then enable inject ati and fix display also you for framebuffer set some random word, that sshould help you. :thumbup:
Shaneee liked this
by: johnsandesh
#51128
Hi, I have a similar laptop with a graphics problem and rest everything is working fine. Graphics show AMD Radeon 7500/7600 4MB
I have the same issue with my 57800 and sleep/wake[…]
I have the same HW. I have an USB Keyboard and a U[…]
I wanna your efi,and try it.Would u like to send t[…]
I need your advice
High Sierra. The GPU is holding you back.
