by: Shing_ex
#24229
Shaneee wrote:My CC 2017 is crashing when saving a file. I'll look into this more when I've got time.
Do u solve the problem?
sabsare liked this
#24236
No I've not been able to get it working. I use PS5 anyway as I prefer it and it works just fine.
by: Kipran
#28249
I've solved issue with PS CC 2017, when it crashed if I changed font. The solution is - deleting Deep_Font folder in Photoshop CC 2017.app
Go to Photoshop install folder, when right click on Adobe Photoshop CC 2017, click "Show Package Info"(or something similar). Go to Contents>Required and delete Deep_Font folder!
That's works for me. Good luck
danielpk, DigitalNox, Lynx and 3 others liked this
by: danielpk
#28778
Kipran wrote:I've solved issue with PS CC 2017, when it crashed if I changed font. The solution is - deleting Deep_Font folder in Photoshop CC 2017.app
MY GOD! i've been searching high and low for a solution, verified my fonts and etc...Thank you so much :D
by: DigitalNox
#28842
Kipran wrote: Sun Oct 01, 2017 4:11 am I've solved issue with PS CC 2017, when it crashed if I changed font. The solution is - deleting Deep_Font folder in Photoshop CC 2017.app
Oh, thank you, thank you, HUGE
by: AlGrey
#30475
Are you guys successful with photoshop 19.0.0 (19.0.0.277) ? Crashing at boot :(
(19.25 KiB) Downloaded 10 times
by: Lynx
#30643
Thank you so much!
by: skadush
#32475
You sir deserve a cookie!
