by: skadush
#12836
I just realize that photoshop is crashing every time you change the font. happens to my el capitan as well. Im not sure if this is because of hackintosh or PS problem. Anyone having this issue?
tobyni liked this
by: Ackados
#12839
Is this Adobe Photoshop? And it's the program that crashes, not the OS X? Odd. Using Clover?
by: skadush
#12840
Ackados wrote:Is this Adobe Photoshop? And it's the program that crashes, not the OS X? Odd. Using Clover?
Yeah its photoshop. the program crash not the OSX. Been searching a solution for a while still all failed. Even booted to safe boot same problem. Crashing when selecting font. Still happens on El capitan.
Yeah I am using clover
#12854
What version of PS? Have you removed the MMXCore plugin? This fixes alot of issues.
by: skadush
#12977
Shaneee wrote:What version of PS? Have you removed the MMXCore plugin? This fixes alot of issues.
I check the adobe plugins folder and its not there. I am using adobe cc 2017. I didnt install any plugins.
#12999
Hmm not sure. Open the Console app and check the PS crash log.
by: redstoneforge
#20581
I have the same problem on Sierra with Photoshop CC 2017. I've reinstalled and deleted MMXCORE and it hasn't solved the issue
by: Meiton
#20585
It is the same for me, Photoshop is crashing while clicking on font list in text tool, I have also tried two different versions of PS CC 2017, but both are crashing.
by: Meiton
#20628
OK so I've tried CS6 13.0 yesterday and it's working just fine after deleting MMXCORE.plugin. I can live with that although It would be nice to get working CC 2017 version of Photoshop.
#20744
My CC 2017 is crashing when saving a file. I'll look into this more when I've got time.
Meiton liked this
