by: kv21
#12790
Hi Guys I manage to boot into sierra and install elan , battery kext on my n551zu (fx-7600p)
but I got some graphical lag and missing slider I tried using rehabman acpi backlight kext and intel backlight kext but it doesn't work (is there anyway to have slider working without brightness slider app?) and how to fix graphical lag its really annoying.
nb : is it needed to patch dsdt n ssdt on amd?
thanks before :)
#12816
The laggy graphics is because of the integrated GPU. These aren't supported on macOS. You can try with this but I can't be sure,
http://www.insanelymac.com/forum/topic/291117-how-to-make-radeon-desktop-or-mobility-be-working-by-using-clover/
