#53747
Zrzut ekranu 2020-01-15 o 11.51.45.png (91.84 KiB) Viewed 882 times
Build
Motherboard: Gigabyte X570 Aorus Pro (witohut I)
CPU: AMD Ryzen 5 3600X
CPU Cooler: Amd Wraith Spire
GPU: Gigabyte Radeon RX 5700 XT GAMING 8G OC
Memory: G.Skill DDR4 16 GB 3466-CL16 - Dual-Kit - Trident Z RGB
Storage: SSD Lite-On MU 2 (PH3-CE120)
Bluetooth: None
Wifi: None
Case: Phanteks Eclipse P400 Air DRGB
Power Supply: Seasonic M12II EVO 80Plus Bronze 750W
Monitor: BenQ EW2440L
MacOS: 10.15.2 (19C57)
OpenCore: 0.5.4
BIOS: F11
Benchmarks
Spoiler:
Zrzut ekranu 2020-01-15 o 12.22.22.png (65.79 KiB) Viewed 882 times
Zrzut ekranu 2020-01-15 o 12.09.58.png (1.71 MiB) Viewed 882 times
OpenCore
Spoiler:
ACPI
- SSDT-PLUG.aml (still not working )
- SSDT-EC-AMD.aml
- SSDT-USBX.aml (fix USB power)
Kexts
- Lilu.kext
- WhateverGreen.kext
- VirtualMC.kext
- AppleALC.kext
- SmallTreeIntel82576.kext (Intel ethernet)
- AGPMInjector.kext (Proper video injection. Depends on video and smbios)
SMBIOS
iMacPro1,1
Drivers
- ApfsDriverLoader.efi
- HFSPlus.efi
- FwRuntimeServices.efi
- VBoxHfs.efi
Working:
Audio
GPU
LAN
Shutdown
USB Power
Reboot
Hibernate
Not working:
Wifi - don't have it on MB
Bluetooth - don't have it on MB
Thunderbolt
System freeze after 10 min of idle - temporary solution - Amphetamine
______________________________________________________________________
UPDATE:
- SMBIOS changed to iMac 19,1 - no more kernel error :)
- SSDT-plugin - manage to work witohut nullcpupowermanagment
- kexts updated
[/code]
(1.5 MiB) Downloaded 158 times
#53803
Hi - would you be able to share your EFI? I'm troubleshooting my build as I also have kernel panics due to power state changes though.
Thanks,
Tom
#53845
Hi many thanks, would you be able to share your Boot files as well? I'm having issues (I think) with my NVME being seen properly, using BIOS F11, did you need to change anything? Thanks again!
hi hereditarium, I managed to get it to the point were OS X is installing - I was doing something stupid with OC vs Clover. My problem is three quarters of the way through the install process I get a big stop sign come up and it goes no further! is there a BIOS setting I'm missing?
Update managed to get to install phase, by not using the 3.1 USB port - once I switched the USB stick to usb 3.0 port it worked!
Again thanks so much to hereditarium, for helping me out with the EFI folder! I have managed to get my system up and running! All looking good, had some complications with install (main on being OSX saying it could not proceed as it needed some critical files, after plugging in the internet and leaving it for a while, the error cleared !?!? So I suspect it was downloading some updates or something in the background) after that install was straight forward. Bluetooth works all fine, as does NVME, only thing not working at present is WIFI.
Some more benchmarks
Another update, getting really bad openCL performance - 8,385 :cry: , in metal I get 39,882 using geek bench. Anyone any ideas on how to fix the openCL or have any better scores?
Can confirm Bluetoth working,
Problems:-
1) Poor performance on openCL
2) USB 3.1 not working neither is usb-c.
3) Sleep not working
4) Wifi not working (expected I guess)
anyone know which Ktexts or SSDT's I should be using to solve any of these for x570 MB?
Another update.
Sleep not working
USB 3.1 Gen2 not working (other USB 3.1 Gen1 ports are working fine), looks like there is a second controller on this board that deals with the usb-c & Gen2 USB 3.0, haven't worked out how to get these working yet, anyone else had success?
Screenshot 2020-01-20 at 13.38.37.png (3.24 MiB) Viewed 709 times
hereditarium liked this
