#56760
@ftln46, Are you using MacProMemoryNotificationDisabler.kext? It requires WhateverGreen to work (for some reason I don't know...). If you don't want to use WhateverGreen you have to disable MacProMemoryNotificationDisabler too (and maybe switch to iMacPro1,1 instead to avoid the warning).
#56762
You have to adapt the USBPorts and the AGPMInjector kext if you’re using them. The last one can be replaced with the RadeonBoost if you didn’t already. That one supports iMacPro as well.
#56775
Hi,
I will have to research on the USB ports how to build this, any tips ?
With regards to running without WhateverGreen I just have to be careful not to click on about this mac and I can safely close the notification at boot.
Cinebench show no impact on performance with or without.
Getting around 9600pts in R20.
#56777
You can open the Info.plist of the USBPorts kext and just change all "MacPro7,1" to "iMacPro1,1" nothing more to do. You can also create a new one with the Hackintool, but you need to switch the SMBIOS beforehand.
ftln46 liked this
#56785
All done, up and running without WhateverGreen Memory & MacProMemoryNotificationDisabler :)
Also seem to have won an extra 100pts in Cinebench :thumbup:
Screenshot 2020-04-22 at 22.35.44.png (133.74 KiB) Viewed 1156 times
Hi,
May I ask how you created the DeviceProperties section in the config.plist?
Specifically where did you get all the Pci addresses from?
Example:
			<key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/Pci(0x5,0x0)/Pci(0x0,0x0)</key>
			<dict>
				<key>AAPL,slot-name</key>
				<string>[email protected],1,2/0,0/5,0/0,0</string>
				<key>device-id</key>
				<data>xx:xx:xx:xx:xx</data>
				<key>device_type</key>
				<string>Ethernet Controller</string>
				<key>model</key>
				<string>I211 Gigabit Network Connections</string>
				<key>name</key>
				<string>Intel I211 Ethernet</string>
				<key>vendor-id</key>
				<data>hoAAAA==</data>
			</dict>
Apophis liked this
#56932
Apophis wrote:I've used the Hackintool which has a tab with all PCI devices
Thanks, I just manage to disable the NVME controller as my NVME SSD with windows install is causing kernel panics.
panic(cpu 0 caller 0xffffff7f944a2231): nvme: "Fatal error occurred. CSTS=0x1 US[1]=0x0 US[0]=0x1b1 VID=0x144d DID=0xa808
. FW Revision=EXA74D1Q\n"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-470.100.17/IONVMeController.cpp:5320
Backtrace (CPU 0), Frame : Return Address
0xffffff87411439e0 : 0xffffff80115215cd mach_kernel : _handle_debugger_trap + 0x49d
0xffffff8741143a30 : 0xffffff801165a3c5 mach_kernel : _kdp_i386_trap + 0x155
0xffffff8741143a70 : 0xffffff801164bf7e mach_kernel : _kernel_trap + 0x4ee
0xffffff8741143ac0 : 0xffffff80114c7a40 mach_kernel : _return_from_trap + 0xe0
0xffffff8741143ae0 : 0xffffff8011520c97 mach_kernel : _DebuggerTrapWithState + 0x17
0xffffff8741143be0 : 0xffffff8011521087 mach_kernel : _panic_trap_to_debugger + 0x227
0xffffff8741143c30 : 0xffffff8011cc2c7c mach_kernel : _panic + 0x54
0xffffff8741143ca0 : 0xffffff7f944a2231 com.apple.iokit.IONVMeFamily : __ZN16IONVMeController8PolledIOEhP18IOMemoryDescriptorjyy18IOPolledCompletionjPKhm.cold.1
0xffffff8741143cc0 : 0xffffff7f9448d362 com.apple.iokit.IONVMeFamily : __ZN16IONVMeController18RequestAsyncEventsEj
0xffffff8741143e20 : 0xffffff8011c33949 mach_kernel : __ZN18IOTimerEventSource15timeoutSignaledEPvS0_ + 0x89
0xffffff8741143e90 : 0xffffff8011c33869 mach_kernel : __ZN18IOTimerEventSource17timeoutAndReleaseEPvS0_ + 0x99
0xffffff8741143ec0 : 0xffffff8011563545 mach_kernel : _thread_call_delayed_timer + 0xec5
0xffffff8741143f40 : 0xffffff8011563071 mach_kernel : _thread_call_delayed_timer + 0x9f1
0xffffff8741143fa0 : 0xffffff80114c713e mach_kernel : _call_continuation + 0x2e
         com.apple.iokit.IONVMeFamily(2.1)[3DB9BFC6-422F-39A2-A445-AB2732CE5BFC]@0xffffff7f9447f000->0xffffff7f944c1fff
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[5EF51D44-9FC7-357F-9FB7-3468FD748382]@0xffffff7f92ab9000
            dependency: com.apple.iokit.IOPCIFamily(2.9)[1B1F3BBB-9212-3CF9-94F8-8FEF0D3ACEC4]@0xffffff7f91f31000
            dependency: com.apple.driver.AppleEFINVRAM(2.1)[6B3E9057-454A-3220-8AE3-424808CDA9E5]@0xffffff7f92d33000
            dependency: com.apple.iokit.IOStorageFamily(2.1)[425BC668-32EC-368C-B4EB-CF8510846BEE]@0xffffff7f9229d000
            dependency: com.apple.iokit.IOReportFamily(47)[337B24B2-0261-3521-8D1B-23387FC1D657]@0xffffff7f92459000
I replaced the device properties following this guide: https://dortania.github.io/OpenCore-Des ... ?h=disable
  • 1
  • 11
  • 12
  • 13
  • 14
  • 15
