#56620
It's doable. You just have to generate the proper MLB/SystemSerialNumber. Additionally you've to re-generate the AGPMInjector and USBPorts kexts if you're using them but that should be all.
I was also initially using iMacPro1,1 before switching to MacPro7,1 and I didn't notice any issues.
#56682
Regarding Sleep, it seems to work best when disabling the USB controller of the CPU in the BIOS for good: AMD PBS -> FCH Common Options -> XCHI Controller 0 to disabled
#56720
@ckrueger99 It sure seems like I shouldn’t have to. I just got my replacement board back from ASRock yesterday (Saturday 4/18) so I will test it out in the next few days as I rebuild my system. For me the TB3 port is the main port for all I pan to do. So as long as this port is not compromised I am good for this build.
Apophis liked this
#56733
Short update: I've tested CMMChris' RadeonBoost.kext (https://www.hackintosh-forum.de/forum/t ... /?pageNo=1) yesterday and got about 25% improved Metal performance in Geekbench 5 out of my 5500 XT. It also provides AGPM injection at the same time. Although the thread is in German it contains a lot of interesting findings.
#56735
Hi, I've got a problem with second part of install. Install stopped on some panic info, but I can't discover what make that problem. If someone will be kind and can look in my EFI and config.plist i will be more than happy :)
My EFI folder
https://mega.nz/file/t4ZCzagJ
Hi, just wanted to say I followed this thread and seem to have succesfull install on same motherboard with 3950x :) , I'm not sure if I need to fine tune CPU powermanagement because of more cores than 3900x though.
Had to install to SSD as I get system crash in disk utility with PM981 NVME.
Thanks OP :)
Processor (CPU)
CPU Name	AMD Ryzen 9 3950X 16-Core Processor
Threading	1 CPU - 16 Core - 32 Threads
Frequency	4024.06 MHz (40.25 * 99.98 MHz) - Uncore: 1799.6 MHz
Multiplier	Current: 40.25
Architecture	Matisse / Stepping: MTS-B0 / Technology: 7 nm
CPUID / Ext.	F.1.0 / 17.71
IA Extensions	MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Caches	L1D : 32 KB / L2 : 512 KB / L3 : 16384 KB
Caches Assoc.	L1D : 8-way / L2 : 8-way / L3 : 16-way
Microcode	Rev. 0x8701013
TDP / Vcore	105 Watts / 1.248 Volts
Temperature	78.3 °C / 173 °F
Type	Retail
Cores Frequencies	#00: 4024.06 MHz  #01: 3999.07 MHz  #02: 4024.06 MHz  #03: 4024.06 MHz 
#04: 3999.07 MHz  #05: 4024.06 MHz  #06: 3999.07 MHz  #07: 4024.06 MHz 
#08: 4024.06 MHz  #09: 3999.07 MHz  #10: 4024.06 MHz  #11: 4024.06 MHz 
#12: 3999.07 MHz  #13: 4274.00 MHz  #14: 4024.06 MHz  #15: 3999.07 MHz 
Motherboard
Model	ASRock X570 Phantom Gaming-ITX/TB3
Socket	Socket AM4 (1331)
North Bridge	AMD Ryzen SOC rev 00
South Bridge	AMD X570 rev 51
BIOS	American Megatrends Inc. P2.00 (11/26/2019)
Memory (RAM)
Total Size	65536 MB
Type	Dual Channel (128 bit) DDR4-SDRAM
Frequency	1799.6 MHz (DDR4-3600) - Ratio 3:54
Timings	18-22-22-42-84-2 (tCAS-tRC-tRP-tRAS-tCS-tCR)
Slot #1 Module	Corsair 32768 MB (DDR4-2137) - XMP 2.0 - P/N: CMW64GX4M2D3600C18
Slot #2 Module	Corsair 32768 MB (DDR4-2137) - XMP 2.0 - P/N: CMW64GX4M2D3600C18
Graphic Card (GPU)
GPU Type	AMD Radeon VII (Vega 20) @ 114 MHz
GPU Brand	ATI Technologies
GPU VRAM	16368 MB @ 416 MHz
Storage (HDD/SSD)
Model #1 Name	SKhynix SC300 HFS512G32MND-3210A (FW: 20131P00)
Model #1 Capacity	476.9 GiB (~510 GB)
Model #1 Type	Fixed, SSD - Bus: SATA (11)
Model #2 Name	SKhynix SC300 HFS512G32MND-3210A (FW: 20131P00)
Model #2 Capacity	476.9 GiB (~510 GB)
Model #2 Type	Fixed, SSD - Bus: SATA (11)
Model #3 Name	PM981 NVMe Samsung 512GB
Model #3 Capacity	476.9 GiB (~510 GB)
Model #3 Type	Fixed, SSD - Bus: NVMe (17)
Display
Screen #1	ROG PG279Q (ACI27EC)
Screen #1 Spec	27.2 inches (69.1 cm) / 2560 x 1440 pixels @ 30-165 Hz
Miscellaneous
Windows Version	Microsoft Windows 10 (10.0) Pro for Workstations 64-bit
CPU-Z Version	1.91.0 (64 bit)
#56748
Nice build :thumbup:
Yes, some Samsung NVMe SSDs have issues and require at least a firmware upgrade as far as I know (don't have one).
The only thing bound to the number of cores is the VoodooTSCSyncAMD, but you can just edit the contained Info.plist and adjust to your thread count.
#56755
I think I spoke to soon :)
I created a new VoodooTSCSyncAMD for 32 thread and set "WhateverGreen.kext" in Kernel to "enabled=False" in config.plist and now I get the following notification at boot:
"Memory Modules Configured, More than the maximum supported memory is installed in your Mac."
And instant hard reset of PC if I click on about this mac.
Any Ideas ?
(6.53 KiB) Downloaded 33 times
ftln46 wrote:I think I spoke to soon :)
Any Ideas ?
All is still working well though apart from notification and instant reboot.
EDIT - A bit more troubleshooting show setting 31 threads in VoodooTSCSync is good, but when disabling WhateverGreen I get memory error and instant reboot crash on "About this mac".
  • 1
  • 11
  • 12
  • 13
  • 14
  • 15
