#55102
rykr wrote:
lvcraig wrote:@adliswil
I'm using the same board as the OP with the RealtekRTL8111.kext and have stable, functional ethernet.
I'm looking at picking up this board for a hack. Are you 100% sure that Catalina with the RTL8111 kext supports the L8200A?
Thanks!
As sure as I'm replying to this message from said Hackintosh connected via ethernet...
Screen Shot 2020-02-27 at 11.01.19 PM.png (492.18 KiB) Viewed 341 times
#55146
If someone has issue with sound on this motherboard ( i am using version without wifi ) then i resolved it basically using applealc guide by setting only those two things despite of having proper kexts:
alcid=1 in boot args text mode in clover configurator
Set Devices → Audio → Inject = NO (Necessarily type string!) in clover configurator
#55628
nikim wrote: Sat Feb 29, 2020 8:27 pm If someone has issue with sound on this motherboard ( i am using version without wifi ) then i resolved it basically using applealc guide by setting only those two things despite of having proper kexts:
@nikim
I don't have alcid=1 in my .plist? Could you explain in detail? Thanks a lot!
#55898
adliswil wrote:@adliswil don't have it because you need to add it:
https://github.com/acidanthera/AppleALC ... -and-usage
as it is stated here, just add it to boot args in text mode.
so here:
<key>boot-args</key>
<string>-v npci=0x2000 debug=0x100 keepsyms=1 agdpmod=pikera</string>
so here:
