#51337
About this Mac
About this Mac
Captura de Pantalla 2019-09-30 a la(s) 10.44.28 a. m..png (125.98 KiB) Viewed 1599 times
First Ryzentosh and everything without problems.
Specs:
CPU: Ryzen 5 2600
MoBo: Asus A320m-k
GPU: Gigabyte RX560
SSD: Adata SU650 480 GB
RAM: Corsair Vengeance 2x8Gb 3000Mhz
Peripherals:
Keyboard: HyperX Alloy FPS
Mouse: Logitech G502
Monitor: ASUS VP228
Process:
Use the Shaneee tutorial: https://vanilla.amd-osx.com/
Also support me from the page: https://amd-osx.com/faq/
These are the Kext that I use:
Kext that I use
Kext that I use
Captura de Pantalla 2019-09-30 a la(s) 9.47.39 a. m..png (37.72 KiB) Viewed 1599 times
I only made one change at the end of the installation: after installing MacOS on the PC and performing the initial configuration, do not install Clover on the EFI partition, all I did was mount the EFI partition of the new installation with Clover Configurator and copy the EFI folder from the USB to the EFI partition. Change the boot in the BIOS and boot without problem.
At first I used an Asus GTX 1050ti Cerberus GPU but because there are no Web drivers for Mojave and I did not want to install High Sierra I opted to switch to an RX560.
What works:
UBS (all)
Ethernet
App Store
Sleep / wake
iTunes, iCloud, iMessage
Audio (Apple ACL):
- For the codec of this MoBo inject 7 in config.plist
Apple ACL
Apple ACL
Captura de Pantalla 2019-09-30 a la(s) 10.52.09 a. m..png (6.31 KiB) Viewed 1599 times
I'm waiting for the fenvi T919 card (https://www.amazon.com/gp/product/B07VC ... XWEAH&th=1) to have Wifi-BT OOB
At the moment there is nothing that I have identified that does not work.
If anyone has any questions about whether something does not work, let me know and I will try it.
I thank the entire community for the effort they make to make this possible.
Greetings from Mexico.
Rodoruiz97 liked this
