by: AstonJ
#51134
Hi guys
would someone be so kind to tell me the process of updating my Hackintosh running Mojave 10.14.1 to the last 10.14.6?
#51138
It's simple. Apply the kernel patches to your Clover config from the github repo here, https://github.com/AMD-OSX/AMD_Vanilla
Or use this script from CorpNewt to add the patches automatically, https://github.com/corpnewt/AMDVanillaPatches
Once you've got the patches added to your config run the update from System Preferences as you would on a normal Mac.
by: AstonJ
#51182
Thanks a lot! Shanee :clap: :thumbup: I will do it right now :)
You need the latest clover. Get it at the github u[…]
AMD Vanilla Tutorials
Hello, I'm trying to install Mojave on my desktop […]
Do you have acceleration with this web driver?
Thank you, all working now :)
