by: Ajit H
#50906
Hi
I installed Mojave 10.14.16. At first everything installed perfectly other than D-Link DWA-123 D1 wifi driver.
After that I find the chipset of the above wifi adapter which is RTL8188ETU. For this I downloaded the driver from this link
https://github.com/chris1111/Wireless-U ... ter-Clover
Now everything works perfectly as it should. Already installed Visaul Studio for Xamarin development.
Kexts used:
Screenshot 2019-08-29 at 7.08.31 PM.png (41.19 KiB) Viewed 76 times
Benchmark.
Screenshot 2019-08-30 at 1.02.10 PM.png (63.27 KiB) Viewed 62 times
Thanks for all those who made OSX installation on Amd.
Regards
Ajit
valdecifreire liked this
