#50886
Over the past couple of months I have been working on getting Mojave working on this laptop. It is unique because it is the only laptop with a B450 chipset supporting Ryzen 1+ processors and a Vega56 GPU.
  • Ryzen 2700
    [*[B450 Chipset
  • Vega56
  • 144Hz 17 inch AUO IPS panel
  • DW1560 M.2 card installed for wifi / bluetooth support
  • Samsung 970 Evo 1TB
Not working:
  • Internal LCD displays static when being re-enabled other than from a reboot
  • Sleep instantly wakes
  • Battery status isn't available when using the iMacPro1,1 SMBIOS
  • Internal Microphone when using AppleALC (speakers do work)
  • Internal keyboard isn't always detected when booting, when using VoodooPS2Controller (Rehabman) or VoodooPS2 (acidanthera)
  • Internal Trackpad doesn't have configuration options available in System Preferences
Over all the machine is pretty viable for what I am using it for (Xcode / Android builds) although it appears that running the Android Simulator isn't possible due to lack of Intel HAXM support. I will update this as more things are fixed.
Sleep wake solutions?
This also happens on my machine. I've first just[…]
Hey there :wave: I have the same issue with my 2[…]
hi guys, thanks for all the hard work getting thi[…]
You'll get it recognised with full resolution but […]
