#50732
Hello Forum,
I follwed different Sources to get the Vanilla Install working.
1) I used a Installer from a german forum (hackintosh-forum.de) named "S-Installer".
2) I used a Image for a Clover USB-Boot-Stick (hackintosh-forum.de) , what only contains Clover for legacy BIOS and AMD FX for macOS 10.13.6 to 10.14.6 with the Vanilla patches (15 = AMD FX).
3) I used the Account fix like "sam298"
After installation, at data and privacy screen it reboots. To fix, I created temporary user per instructions here under update 2
https://www.insanelymac.com/forum/topic ... nt-2658085
Issues Hardware: Only USB 3.0 Ports of my NEC USB Card does not work.
Issues Software: Safari makes problemes with Youtube and sometimes also with "normal Webpages".
Regards, Olaf from Germany
Egress liked this
