by: SekaiNew
#50507
Specs:
CPU: AMD Ryzen 5 2600X
MB: Gigabyte B450 AORUS ELITE
RAM: Crucial Ballistix Sport LT 32GB DDR4 2600mhz(16GBx2)
HDD: Kingston A400 SSD 480GB
GPU: Sapphire Pulse RX580 8GB
Monitor: LG 27UL500-W 4K FreeSync
Process:
I used this tutorial https://vanilla.amd-osx.com/
I needed internet to install (I didn't know it).
There was a problem when I clicked on continue installation, I opened the terminal and wrote: sudo sntp -sS time.apple.com after that i installed normally.
After Configure Clover i could reset my hackingtosh but no audio... i fix using this tutorial https://www.youtube.com/watch?v=9XRVXLcGaXc
Like many others in about this mac i got unknown processor, so i followed this tutorial https://climbjoe.tv/fix-unknown-processor-mac/(only the part when you edit the name and copy the file to the path, i just reset my hackingtosh and i was ok) i used BBEdit to edit the file.strings
For Mobile Developers
No problem instaling xcode but there was a problem installing android studio, was about mksdcard i just ignore this and i am using genymotion which gave 1 problem vboxheadless was using high cpu(100%), i fixed using virtualbox 5.2.32 instead of version 6.
PS> I followed the process installation from this tutorial https://www.youtube.com/watch?v=GZ_72oP58mY but the configuration i used the mentioned before.
Sorry for my bad english.
Thanks Shaneee was so helpfull now i am using my hacking without problem.
Sleep wake solutions?
This also happens on my machine. I've first just[…]
Hey there :wave: I have the same issue with my 2[…]
hi guys, thanks for all the hard work getting thi[…]
You'll get it recognised with full resolution but […]
