#50501
Specs:
CPU: AMD Ryzen 9 3900x
Motherboard: Asus ROG X570 Crosshair VIII (Wi-fi)
RAM: G.Skill TridentZ 32GB DDR4 3000MHz
HDD: Crucial MX500 1TB
USB : 2.0 & 3.1
GPU: AMD Vega 56(with Vega 64 BIOS and Liquid Cooler)
WiFi: BCM94360 PCI-E 1300M 5G AC
Monitor: Dell U2717D LCD
Bootloader: Clover Ver.r5033
I followed the vanilla guide here: https://vanilla.amd-osx.com/ Thanks to everyone who contribute to this great method!
Working:
- App Store, iCloud, iMessage and Facetime
- Hardware Acceleration in H.264 & HEVC
- HiDPI
- USB 2.0 & 3.1
- Bluetooth module works smoothly without any extra kext
- WiFi
- Airdrop
- Airplay
Not Working:
- OS HDD shows as "External"
- Ethernet
- Audio
- Intel SSD DC P4510 2T
As I rarely use a cable connecting internet, I didn't take much time to driver this Intel i211 AT ethernet card. And I'm using a SONY SRS-X88 as speaker, so I did nothing to config the audio issues (I did have a AppleALC in my kexts folder however it didn't work).
I have an Intel SSD DC P4510 2T for my Windows HD, however it causes Kernel panic in clover. So I have to remove it from the motherboard so that I can continue the Hackintosh installation. Still finding solutions, maybe I can disable it with SSDT somehow. :)
Egress liked this
#51184
elegygrey wrote: Fri Aug 02, 2019 7:30 pm Specs:
USB : 2.0 & 3.1
Working:
- HiDPI
- USB 2.0 & 3.1
- WiFi
- Airdrop
- Airplay
Not Working:
- Ethernet
- Audio
Yes, if you please. Your BIOS settings would be most useful. Thanks. :thumbup: :clap:
