#50413
Everything is working except sleep which I believe is because my GTX 1060 won't switch off completely. I'm really hoping for the fix.
My specs are in my signature.
Currently running Windows 1903 with Mojave 10.14.6
Kexts:
- AppleALC
- Lilu
- NullCPUPowerManagement
- RealtekRTL8111
- VirtualSMC
- WhateverGreen
Config:
- The one made by myself
GT730 is giving me the support for Mojave too! It's a DDR3 version of GT730 so it is natively supported. Remember that GT730 GDDR5 version will NOT work.
Really appreciate the helps in this community. :thumbup:
muy buenas recien instale mac os highy sierra en […]
Black Screen before installation
I had the same issue. Try unplugging and plugging […]
I too have ATI 7610m and the zip file is corrupt[…]
Ryzen 5 with Nvidia 1060
Hi @Johnata , Many thanks for reply. Sorry, toda[…]
