#50127
Components used
  • ASRock Fatal1ty AB350 Gaming-ITX/ac
  • AMD Ryzen 5 1600
  • MSI Radeon RX 570 ARMOR 4G OC
  • Samsung 960 EVO 250GB (NVMe)
  • ADATA 8GB DDR4 3000 U-DIMM XPG CL16
What does work
  • Network (GigaLAN Intel® I211AT)
  • Graphics card (RX570, out of the box)
  • Sound (ALC1220)
  • iMessage (did not tried Facetime)
What does not work
Wifi + Bluetooth, won't work because of the intel chip
Used kexts
  • AppleALC (inject Audio 11)
  • FakeSMC
  • Lilu
  • NullCPUPowerManagement
  • SmallTree-Intel-211-AT-PCIe-GBE
Used drivers (clover)
  • ApfsDriverLoader-64.efi
  • AptioMemoryFix-64.efi
Used the config.plist from https://github.com/AMD-OSX/AMD_Vanilla/ ... nfig.plist
I've installed Mojave 10.14.6 on my Ryzen 1600X an[…]
Stuck at Random Seed
As I see in your config.plist there are no kernel […]
Parallels blank screen
I do not use it for games, with the guest addition[…]
could i have your config, please
