#49668
About This Mac.png (224.64 KiB) Viewed 124 times
Working:
iMessage
Sleep
Ethernet
GPU acceleration
XMP RAM
All USB Ports
Not Working:
FaceTime
----"You cannot sign into FaceTime on this Mac at this time."
32-bit applications
----Using the stock kernel with these patches, so OPEMU is unavailable
Audio:
----All outputs work, but they constantly crackle and stutter; strangely enough, violently shaking the mouse alleviates this
I followed the Vanilla Mojave Installation Guide for the most part, except I used the stock kernel with clover patches instead of the patched 10.14.5 kernel. The system is running smoothly and is performing very well, with a Cinebench score of 1338.
The UEFI settings I used (Gigabyte B450 Aorus M):
Spoiler:
CSM: Enabled
Legacy USB: Enabled
CPU Core Performance Boost: Disabled
SATA Mode: AHCI
Integrated Graphics: Disabled
AMD Cool 'n Quiet: Off
SVM: Enabled
FTPM: Off
(X/E)HCI Handoff: Enabled
Serial Port: Off
Parallel Port: Off
Above 4G Decoding: Off
IOMMU: Off
