#48292
first I follow the guide from ""SHANEEE"""" to have AMD mackintosh then I use https://github.com/AMD-OSX/AMD_Vanilla to install patches and config. after that I download full Mojeva files from Apple Store and install it. (Be warning if u just download 2 files from https://github.com/AMD-OSX/AMD_Vanilla and restart your pc to test out if it boot or not I can tell u it will not able to boot to your Hackintosh). Right now, everything is working for me but I'm not sure if sleep/wake up working or not though. I'll comfirm when I let my PC to sleep for long period.
:thumbup: :thumbup: :thumbup: :thumbup:
why memory speed in this one reading is incorrect and how to change it to correct one. my memory speed is 3200 and it only able to show 1600
updating my AMD condition now. Sleep mode is working with latest Mojave version. after 5 hours of sleeping it wake up fined for me.
#49553
Hello ,I have the same conf that you except for Ryzen 5 2600x. i have sucesffully installed High Sierra. Can you help me to update to Mohave? Can you guide me?
Thank you.
OnSale wrote:
Tue May 28, 2019 7:10 am
Did you fix the memory speed? I am having the same issue.
#49613
"why memory speed in this one reading is incorrect and how to change it to correct one. my memory speed is 3200 and it only able to show 1600"
I am having same issue, but only on Mojave, on HS (Vanilla) the memory speed is correct
SSD Very slow
AMD OS X is the registration forum to get the full[…]
看到中文好亲切, 我已经放弃使用Adobe了, 用老版本吧
@anielk , no, didn't. i realized problem is my 1[…]
Anyone found any fixes for this? still having stut[…]
