#48108
I've got OSX up and running on a Samsung 860 SSD. Will boot into OSX and everything, runs Ableton and Reason without issue... but I cannot get my system to install the updates to 10.14.5 as it is still running 10.14.1. Any advice, tips or pointers will be appreciated .
#48139
Hi John,
We have very similar systems, I also updated 14.1 -> 14.5 without issues. I updated to the latest kexts before running the combo update (https://support.apple.com/kb/DL2000?locale=en_US)
Can you elaborate on what your problem is?
#48187
Think it's just the fact I haven't used MacOS for a bit. Going to try the combo update. When I installed the 10.14.5 update my system would not reboot. I had to use time machine to recall a backup. Noticed the gaming performance of the Vega 56 is a bit hopeless. Once I found a game on steam that would launch
Which kexts are you running?
Tried to update. Restarted when prompted chose install on "volume" got this message
Error allocating 0x5db6 pages at 0x0000000005bf3000 alloc type 2.
Couldn't allocate runtime area
Error:Aborted returned from boot.efi
Assume I need to edit/disable something in Clover.
#48248
johncarr79 wrote:
Wed May 22, 2019 7:37 pm
I'm using Lilu, WhateverGreen, VirtualSMC, VoodooHDA, RealtekRTL8111 & NullCPUPwrMgmt.
Sounds like Clover issue. But I'm too novice to know for certain...
My tips would be to update your kexts, update Clover if applicable, also consider disabling any kernel patches ( I read that somewhere )
https://hackintosher.com/guides/hackint ... ate-guide/
#48438
I now just have the system freeze when I chose to install the updates in clover on restart. System will boot into 10.14.1 but will not update beyond this.
Got 10.14.5 updated and booting. One not so small problem. My GPU a Vega 56 states it only has 7MB and one display works not two as previously. Any ideas as I'm all out of them now.
SSD Very slow
AMD OS X is the registration forum to get the full[…]
看到中文好亲切, 我已经放弃使用Adobe了, 用老版本吧
@anielk , no, didn't. i realized problem is my 1[…]
Anyone found any fixes for this? still having stut[…]
