#47802
Hi!
After a few months of trial & error I finally got my build to work!!! 8-)
What's working: Xcode, Docker, Apple services (iCloud / FaceTime / Messages / etc.).
The only things that aren't working yet are: my on-board wifi/blouetooth card & on-board sound card line-out jack (digital out works fine).
Many thanks to @XNLC for all the attempts to help me out with my stubborn Gigabyte motherboard & kernel panics I was having.
What finally worked for me was the vanilla Mojave guide (viewtopic.php?f=24&t=5902).
I've created the installer, but skipped adding the AMD kernel, then I've used the Clover kernel patches from https://github.com/AMD-OSX/AMD_Vanilla (with some additional patches provided by @AlGrey).
I'm attaching my final config.plist if anyone would need it.
Kudos to @Shaneee & @AlGrey for all that awesome work you did!
(4.69 KiB) Downloaded 136 times
#47804
Hello.
I have a processor almost identical to yours.
I waiting for the shapire rx580pulse from amazon, since I am currently with strix1060 in windows 10.
Already have the usb waiting for the rx in my hand 8-) .
But I decided to go with the highsierra installer 10.13.6 since Shaneee explains that the modified kernel is only for 10.14.1.
I have seen that many installed 10.14.4.
What are the risks in 14.3 or 14.4 or 14.5 beta?
Your answer maybe gives me security to try it with mojave instead of highsierra.
Thanks bro
#47806
Hi @pali12345,
Yeah, @Shaneee's modified kernel in the guide is for 10.14.1, but I think it's worth to try to use the original (vanilla) kernel with Clover kernel patches (config.plist that I attached already have all of them added).
That was the only way that I could get it to work on my hardware.
I wouldn't recommend to use betas, because you won't be able to find any modified kernel for it (if you'd need one) and kernel patches might also not fully work.
If you're able to access a mac to download the macOS 10.14.4 installer then you'll have the latest stable version up & running :)
#47810
Thanks Suntirx,
Yes I can, my girlfriend has a macbook air.
Basically I am a 3D designer, I need stability and correct functioning of software, blender, vray, photshop, aftereffects, slack, skype etcetc.
Then, would you recommend me to try mojave instead of highsierra ?
Thanks!
#47872
@pali12345, Mojave seems to be running stable to me (I'm a software engineer myself :D )
@mrclan, I've tried running it on KVM under linux before, it was working but very slow. If you are able I think it's worth trying running it on bare hardware (at least then you have more control over any issues if you need to change your BIOS/UEFI settings). You should be even able to run it on a USB hard drive to not risk your other OS being messed up.
#50592
How did you get Docker / VM to work?
What entry was specific to that?
suntrix wrote: Sun May 05, 2019 12:26 pm Hi!
Egress liked this
by: Seyed Hossein
#50946
I'm New user on X399 Aorus Xtreme
Please Help me about the bios setting for install mac OS X
Regards
#51096
I followed this tutorial -> viewtopic.php?f=24&t=3543&p=45524
cataclysm_99 wrote:How did you get Docker / VM to work?
