#46038
Using SATA-based SSD, will try my NVME drive next.
Had to remove -radoff and inject ATI to get the "preinstall" and "amd" stages of the install to work. Post-install stage also required DEINT, and the following GPU FakeID:
0x67df1002 for GPU (shows up as an RX 480 -- which isn't exactly wrong).
Set frequency to 3195 for my Ryzen for theoretical performance improvements.
3200mhz Team Dark Pro memory displays as 2400mhz, but benchmarks make it seem like it is performing at the bios-settings of 3200 CL14
Audio, Network out of the box.
Had to just copy the EFI from the USB drive to the EFI folder for the SSD, as there latest clover configurator would not boot correctly.
See plist if you're having any trouble with gIOScreenLock, or other weirdness due to the RX 580.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>ACPI</key>
<dict>
<key>DSDT</key>
<dict>
<key>Fixes</key>
<dict>
<key>FixDisplay</key>
<true/>
<key>FixShutdown</key>
<true/>
</dict>
<key>Name</key>
<string>DSDT.aml</string>
</dict>
<key>HaltEnabler</key>
<true/>
</dict>
<key>Boot</key>
<dict>
<key>Arguments</key>
<string>-v npci=0x2000</string>
<key>DefaultLoader</key>
<string>boot.efi</string>
<key>DefaultVolume</key>
<string>LastBootedVolume</string>
<key>Legacy</key>
<string>PBR</string>
<key>NeverHibernate</key>
<true/>
</dict>
<key>CPU</key>
<dict>
<key>FrequencyMHz</key>
<integer>3195</integer>
</dict>
<key>Devices</key>
<dict>
<key>Audio</key>
<dict>
<key>Inject</key>
<string>Detect</string>
<key>ResetHDA</key>
<true/>
</dict>
<key>FakeID</key>
<dict>
<key>ATI</key>
<string>0x67DF1002</string>
</dict>
<key>ForceHPET</key>
<true/>
<key>USB</key>
<dict>
<key>AddClockID</key>
<true/>
<key>FixOwnership</key>
<true/>
<key>Inject</key>
<false/>
</dict>
</dict>
<key>GUI</key>
<dict>
<key>Language</key>
<string>en:0</string>
<key>Theme</key>
<string>Lightness</string>
</dict>
<key>Graphics</key>
<dict>
<key>EDID</key>
<dict>
<key>ProductID</key>
<string>0x67DF</string>
<key>VendorID</key>
<string>0x1002</string>
</dict>
<key>Inject</key>
<dict>
<key>ATI</key>
<true/>
<key>NVidia</key>
<false/>
</dict>
<key>RadeonDeInit</key>
<true/>
</dict>
<key>KernelAndKextPatches</key>
<dict>
<key>AppleRTC</key>
<true/>
<key>KextsToPatch</key>
<array>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#1</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
weAMBQAQAACJgw==
</data>
<key>InfoPlistPatch</key>
<false/>
<key>Name</key>
<string>IONVMeFamily</string>
<key>Replace</key>
<data>
weAJBQAQAACJgw==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#2</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
D7aMiIIAAACD+QwPhTIBAA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
D7aMiIIAAACD+QkPhTIBAA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#3</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
AMeDpAAAAAAQAABIi0gISA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
AMeDpAAAAAACAABIi0gISA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#4</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SYnGTYX2dGFBwecMSWP/vg==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
SYnGTYX2dGFBwecJSWP/vg==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#5</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
hv8PAABIwegMD7cPgeH/Dw==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
hv8PAABIwegJD7cPgeH/Dw==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#6_7</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
icGB4f8PAABIAdFIgfn/DwAAdzs=
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
icGB4f8BAABIAdFIgfn/AQAAdzs=
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#8</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
SYHF/w8AAEnB7QxJiwQkSA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
SYHF/w8AAEnB7QlJiwQkSA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#9_10</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
BgIAAEyNuAAQAABMiflIgeEA8P//SYmGGgEAAEmJjiIB
AABBvAAQAABJKfQ=
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
BgIAAEyNuAACAABMiflIgeEA8P//SYmGGgEAAEmJjiIB
AABBvAACAABJKfQ=
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#11</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
AABJiY4iAQAAugAQAABIKQ==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
AABJiY4iAQAAugACAABIKQ==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#12</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
yAAAAEkp17gAEAAATYskJA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
yAAAAEkp17gAAgAATYskJA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#13</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
4b+AQBUGTYnWugAQAABFMQ==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
4b+AQBUGTYnWugACAABFMQ==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#14</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
iWTY+EmBxAAQAABJgccA8A==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
iWTY+EmBxAACAABJgccA8A==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#15</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
Bf8PAABIwegMZvfB/w8PlQ==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
Bf8PAABIwegJZvfB/w8PlQ==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#16</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
weIIQQ+2wcHgDEQJ0EQJwA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
weIIQQ+2wcHgCUQJ0EQJwA==
</data>
</dict>
<dict>
<key>Comment</key>
<string>IONVMeFamily Pike R. Alpha Patch#17</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>
RYTJD5XAD7bAweAMRAnYRA==
</data>
<false/>
<key>Name</key>
<key>Replace</key>
<data>
RYTJD5XAD7bAweAJRAnYRA==
</data>
</dict>
</array>
</dict>
<key>RtVariables</key>
<dict>
<key>BooterConfig</key>
<string>0x28</string>
<key>CsrActiveConfig</key>
<string>0x67</string>
<key>MLB</key>
<string>XA0480HFC295I</string>
<key>ROM</key>
<data>
YIrp////
</data>
</dict>
<key>SMBIOS</key>
<dict>
<key>BiosReleaseDate</key>
<string>08/08/17</string>
<key>BiosVendor</key>
<string>Apple Inc.</string>
<key>BiosVersion</key>
<string>MP51.88Z.0084.B00.1708080528</string>
<key>Board-ID</key>
<string>Mac-F221BEC8</string>
<key>BoardManufacturer</key>
<key>BoardSerialNumber</key>
<key>BoardType</key>
<integer>11</integer>
<key>BoardVersion</key>
<string>1.2</string>
<key>ChassisAssetTag</key>
<string>Pro-Enclosure</string>
<key>ChassisManufacturer</key>
<key>ChassisType</key>
<string>0x07</string>
<key>Family</key>
<string>MacPro</string>
<key>FirmwareFeatures</key>
<string>0xE80FE136</string>
<key>FirmwareFeaturesMask</key>
<string>0xFF1FFF3F</string>
<key>LocationInChassis</key>
<string>Part Component</string>
<key>Manufacturer</key>
<key>Mobile</key>
<false/>
<key>PlatformFeature</key>
<string>0xFFFF</string>
<key>ProductName</key>
<string>MacPro5,1</string>
<key>SerialNumber</key>
<string>XA0494P0HFC</string>
<key>Version</key>
</dict>
<key>SystemParameters</key>
<dict>
<key>CustomUUID</key>
<string>31433142-3044-3743-4539-4143FFFFFFFF</string>
<key>InjectKexts</key>
<string>Yes</string>
<key>InjectSystemID</key>
<true/>
</dict>
</dict>
</plist>
