#45976
I used a Chinese tutorial made by LINGXI based on XLNC\Foxlet\Shaneee's guild (link: https://www.c4dlx.com/thread-654-1-1.html)
Here is my build
CPU: AMD RYZEN 2600
GPU: Sapphire RX570
Motherboard: MSI B450 MORTAR
RAM: Galaxy Gamer II 3000Mhz
SSD: Intel 760p 256Gb
Working: ethernet , USB ports, graphic card.
Not working: Automatic shutdown, Audio.
PS: I have a unsolved problem with Steam. It crash every time I launch it.
#47811
你好!看你的国旗是China(我也是!),就用中文好了!我们用的是同一个镜像lingxi的!
你的usb是怎么处理的!我的声音是正常的,用的是万能声卡驱动!voodoohda.kext
我的配置,2600x,msib450Mortar,gpu蓝宝石rx570,基本和你的相同!
----------English is generated by translation
Hello! Look, your flag is China (me too! ), just use Chinese! We're using the same mirror lingxi! What did you do with your usb?! My voice is normal, driven by a universal sound card! Voodoohda.kext my configuration, 2600x, msib450mortar, CPU sapphire rx570, is basically the same as yours!
#48352
Hello
I have downloaded the Lingxi image
I saw you are using MSI board
Can u show me how do you set the BIOS settings ??
