#45812
System:
CPU: AMD FX-4300 @ 3.8 GHz
RAM: 8GB DDR3
GPU: HP NVIDIA GTX 1050 2GB
Mobo: ASRock 970m Pro3
HDD: 1TB Western Digital Hard Drive
Things That Work: NVIDIA Web Driver, iMessage and FaceTime
Things That I Can't Figure Out: HDMI Audio, Recovery Partition not booting
#45856
Hello snowcuber04, did you use "Enoch" or "Clover" as Bootloader? I have also an AMD FX-4300, a NVIDIA GT 220 GPU and a ASUS M5A78L-M LX with the same Chipsets. I'm running High Sierra 10.13.2, Sierra 10.12.5, ElCapitan 10.11.5 and Yosemite 10.10.5 .
I've installed Mojave 10.14.6 on my Ryzen 1600X an[…]
Stuck at Random Seed
As I see in your config.plist there are no kernel […]
Parallels blank screen
I do not use it for games, with the guest addition[…]
could i have your config, please
