#43993
Captura de Tela 2018-11-16 às 00.54.58.png (57.95 KiB) Viewed 206 times
CPU: AMD Ryzen 7 1700
Motherboard: GIGABYTE ITX GA-AB350N-Gaming-WIFI
RAM: Corsair Vengeance LED 16GB 3000MHz DDR4
HDD: Kingston 120GB x 1TB HDD x 500GB HDD x 320HDD
USB : 3.1 / 3.0 (not working at all)
GPU: GIGABYTE ITX GTX 970 4GB
WLAN & BT: Intel® 802.11ac Dual Band WIFI and Bluetooth 4.2 card (NOT WORKING)
LAN: Realtek RTL8168G/8111G
Sound: HDMI / Motherboard ( AppleHDA )
Sleep: not working
Monitor: 29'' PHILIPS - FLLHD.
Bootloader: Clover
Installation Method: Retail USB
Installed OS': High Sierra 10.13.3
Geekbench CPU:
https://browser.geekbench.com/v4/cpu/10851915
____
A long time I have some experience trying to use hackintosh on my old laptop :D . Now i got a hackintosh with 98% features working on my pc. No headache looking for kexts or DSDT editting. Audio, ethernet, gpu, worked fine since the installation.
Cons: WIFI +BT integrated ones, do not work. (Forums says intel cards are not supported).
Some USB ports do not work when I plug some drives.
My only bad experience was trying to make Adobe CC 2019 work. I took some hours to make it work, looking at forums about this problem. Now Photoshop, Illustrator, Premiere are working flawless.
datdude717 liked this
#44013
Any tips on getting Adobe CC to work? It used to work for me a while back but now all of a sudden, even with the terminal commands, it doesn't seem to work for me :(
#49628
eudigorodrigo wrote: Fri Nov 16, 2018 4:21 am Captura de Tela 2018-11-16 às 00.54.58.png
Sleep: not working
Bootloader: Clover
Geekbench CPU:
____
Can you help me with Adobe AI and PS 2019?
Thank you.
ryzen0800 liked this
