#43956
My configuration
CPU: AMD Ryzen 5 2600X
Motherboard: MSI (MSI) B450M MORTAR
Graphics Card: Gigabyte AORUS GeForce® GTX 1060 6G
Sound card: integrated Realtek ALC892 8-channel audio chip
NIC: Onboard Realtek RTL8111F Gigabit LAN
Current operation:
The graphics card is running normally
NIC is running normally
The speaker is normal, the headset is normal, it is unable to switch automatically, you need to manually switch the output.
USB is working fine, but native - system reports - USB does not display any information
In any case, normal use is enough
Thanks to Shaneee's tutorials and resources, students of the same configuration and approximate configuration can communicate
