by: TaeSeok Kim
#45589
hi good day to you Shaneee... i'm using amd 2400g, asrock b450 gaming itx/ac, gigabyte rx 580 4g, 8x2 ddr4 ram... i installed 10.14.3 (i didn't want it...) according to your guidance... and it has been completed... but have some problems... the unendurable crackling noise always occur... and i couldn't fix it... is there any solution..? how can i solve it..? need your help... thanx in advance...
i did this viewtopic.php?p=45449#p45449 , but this is not because it doesn't work mojave... viewtopic.php?f=24&t=4880
by: whereisdan
#47909
Hi @Shaneee
Do you still have/use your old system, the compaq PC?
I have that exact same PC. I was doing research on how to turn it into a hackintosh and I found your post.
Perhaps you could share your settings, config files and/or kexts required to get it up and running?
I noticed you said you used Enoch on it. I've played with clover a little bit but I have never touched Enoch. Is it easier to implement? Would you recommend it for that hackintosh box over Clover?
Thanks!
#47915
Still have it yet but it now runs Win 10 as a Plex server. It's easy enough to hackintosh but in this day not really worth it. The best it will run is El Capitan.
#49818
Kira.Nguyen wrote:@Shanee
Could you please share me your clover configuration on the first post (GA 350AB - Gaming3...) ?
Thanks
Why? What isn't working that you need looked at?
by: farzad1278
#52021
what is about the sound??
I have change my motherboard from MSI B450m Gaming Plus to Asus Tuf b450 and the current Gigabyte A320m-S2H V2 the sound glitch and stuttering especially playing mp3
Shaneee wrote: Thu Aug 11, 2016 2:14 pm
  • CPU: AMD Ryzen 5 2400G
  • Motherboard: GIGABYTE AB350-Gaming 3
  • RAM: Corsair Vengeance LPX 8GB 3000MHz DDR4
  • HDD: 500GB 960 EVO - Crucial MX500 250GB - 1 x 2TB Seagate - 1 x 640GB WDC - 1 x 500GB WDC
  • USB : 3.1
  • GPU: ASUS RX 560 ROG STRIX 4GB
  • LAN: Realtek RTL8111 ( RTL8111.kext )
  • Sound: HDMI / Motherboard ( AppleALC )
  • Sleep: Works
  • Monitor: 32" HD TV
  • Bootloader: Clover
  • Other: iCloud works OOB. Working Bluetooth.
  • Installation Method: Retail USB
  • Installed OS': High Sierra 10.14.1 - Windows 10 Pro - Few Test Installations
Geekbench CPU:
https://browser.geekbench.com/v4/cpu/11383191
Old FX Build
Spoiler:
  • CPU: AMD FX-4300
  • Motherboard: GIGABYTE 78LMT-USB (rev 6.0)
  • Chipset:-
    North Bridge:
    AMD 760G
    South Bridge: AMD SB710 (SuperVIAATA.kext)
  • RAM: 6GB
  • HDD: 1 x 2TB Seagate (Main Drive) 1 x 640GB WDC 2 x 500GB 1 x 320GB
  • USB : 2.0 / 3.0 ( Works with my USB Fix )
  • GPU: Gigabyte GeForce GT 710 2GB ( Works OOB with InjectNvidia )
  • WLAN: Atheros AR5B91 with PCI Adapter ( Works OOB )
  • Sound: HDMI ( VoodooHDA.kext )
  • Sleep: Works
  • Monitor: 32" HD TV ( Spoofed as Apple Thunderbolt Display )
  • Installed OS': High Sierra 10.13.2 - Windows 10 Pro Insider - Few Test Installations
Geekbench,
https://browser.geekbench.com/v4/cpu/4899493
GPU:
https://browser.geekbench.com/v4/compute/1389975
My Old System:
Spoiler:
Not the best build but it started life out as a Compaq OEM PC. It does the job :geek:
This same build has had every version of OS X since 10.6 installed on it :thumbup:
CPU: AMD Athlon II X2 215 @ 2.70GHz
Motherboard: Pegatron M2N68-LA
Chipset: NVIDIA GeForce 6150SE nForce 430 ( AppleNForceATA )
RAM: 6GB 1066 MHz
HDD: 1x 2TB Seagate 1x 640GB WDC 1x500GB WDC
USB : 2.0 All working front and rear with USBLegacyOff=Yes bootflag
GPU: PNY GeForce GT430 1GB ( Works OOB with GraphicsEnabler=Yes )
LAN: Realtek RTL8201N ( NForceLAN )
Sound: Realtek ALC662 ( Patched AppleHDA )
Sleep: Works ( Sort Of )
Bootloader: Enoch installed to ESP set to auto boot OS X
Other: iCloud on El Capitan works OOB. Working Bluetooth.
Installed OS': El Capitan 10.11.6 - Snow Leopard 10.6.8 - Windows 10 Pro Insider
Any questions feel free to ask.
Edit: Here are my Geekbench results :thumbup:
https://browser.geekbench.com/v4/cpu/1017170
GPU OpenCL:
https://browser.geekbench.com/v4/compute/221178
by: blackjack1942
#52053
Can you share your latest EFI of your build? please upload.
I'm using opencore bootloader but apple alc kext won't load.
I can't boot if I use clover bootloader. please help me.
#52055
blackjack1942 wrote:Can you share your latest EFI of your build? please upload.
I won't share my EFI no. I recommend OpenCore. What's the issue with AppleALC? Assuming you are using Ryzen as AppleALC only works there. You need to add the kext to your config and add a boot arg alcid= and your layout ID. Refer to the AppleALC docs on what layouts to try.
by: blackjack1942
#52058
yeah! I'm using ryzen and I already add AppleALC kext on my config but I don't know how to add a boot arg like alcid= .
here's my opencore EFI
https://drive.google.com/file/d/17w_1Ey ... sp=sharing
by: Apophis
#53552
@Shaneee quick question, how did you change the CPU name? Could not get it to work with Catalina... Still just saying '3.8 GHz' there.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
Hello Guys. My first ryzentosh itx build. I've fol[…]
Hmm I'm not too sure why. The only difference I […]
My hard drive doesnt show up
I've done it, still doesn't show up
Try one or more of the following: Where are y[…]
