#56887
HARDWARE
AMD Ryzen 7 2700X
ASUS ROG STRIX B450-F Gaming
MSI Radeon RX 590 8gb
Corsair 32gb DDR4 RAM 2133 Mhz (4*8Gb)
Samsung SSD 970 EVO Plus 500GB M.2
Corsair RMi Series™ RM850i PSU
Corsair Crystal Series™ 570X RGB Case
WORKING
  • Native Audio
  • Ethernet
  • USB 2.0 and USB 3.1
  • Headphones
  • iCloud,iMessage .. etc
NOT WORKING
  • Wifi+Bluetooth
  • Sleep
GUIDE:
  • Copy My EFI Folder To your Bootable Drive
  • Run SSDTTime And type 4 and then 2
  • Now Copy The '.aml' and '.dsl' Files From Results Folder & Replace To EFI/OC/ACPI
  • Run GenSMBIOS Type 1 to Install MacSerial and Then type 3 to Generate SMBIOS, After that type iMacPro1,1
    Now Without Closing That Window, open ProperTree-master folder and run "propertree". From: File -> Open -> your "config.plist" from EFI/OC/. Scroll Down & Navigate To PlatformInfo -> Generic -> and put new data: Type = SystemProductName, Serial = SystemSerialNumber, Board Serial = MLB, SmUUID = SystemUUID. From That Generated SMBIOS
  • Save / Close / Boot
My EFI
(1.87 MiB) Downloaded 194 times
#57012
Thank you I used your config.plist as I could not get mine to boot. My MB is Asus Prime B450M-A so the chances were good. The only thing I had to change was the Ethernet (mines is Realtek RTL8111)
The only issue I have is that I can only boot with the USB Installer inserted, any idea how I can boot straight to the SSD (WDS 240GB M.2)
Thanks!
#57040
MercuryRev wrote:Thank you I used your config.plist as I could not get mine to boot. My MB is Asus Prime B450M-A so the chances were good. The only thing I had to change was the Ethernet (mines is Realtek RTL8111)
Thanks!
Hi! Did you try this instructions? https://dortania.github.io/OpenCore-Des ... acos-drive
I also recommend checking the BIOS settings. https://dortania.github.io/OpenCore-Des ... s-settings
