#56702
https://github.com/trulyspinach/SMCAMDProcessor
"SMCAMDProcessor
XNU kernel extension for power management and monitoring of AMD processors. Also comes with a plugin for VirtualSMC to export readings to other applications.
Please note that this release is at very initial stage of development, make sure you have a proper backup of your EFI folder and never run on any system that matters."
Amd Power Gadget.png (185.82 KiB) Viewed 678 times
freeubi liked this
#56838
@freeubi
I used your build as a model for setup. I'm however running some mouse movement issue under dual monitor setup. Both my displays are connected with DP1.4. Did you run into that issue as well?
#56995
@freeubi, Great job man!!
Could you tell me why you needed each of these boot arguments? Trying to understand if I will need them as well for my build.
  • keepsyms=1
  • agdpmod=pikera
  • npci=0x3000
  • alcid=1
And why you chose MacPRO 7.1 over other choices?
SMBIOS: MacPRO 7.1 -> yes, i get the warning on the RAM but its working.
Thanks!
