by: Dante_Snake
#12384
Hi Everyone!, i just installed OS Sierra on my system of course with help, because i just quit when El Capitan was so Glitchy for graphical and the developing for AMD was so really Slow, but with Sierra is Amazing how they just get it so fast, here are my system Specs:
MOBO: Asus M5A97
CPU: FX 8320 3.5Ghz OC to 4.1Ghz ( Can't Go further because my mobo don't support it)
RAM: 8GB Adata XPG 1600Mhz
Cooling: Water Corsair H90
GPU: Gigabyte Windforce HD7950 OC
PSU: Cooler Master Silent Pro M1 850W
Monitor: AOC 21.5 FHD
Case: NZXT Phantom 410
8-)
Using Enoch as Bootloader (PS: i used an real Mac to make this possible an Macbook Pro Mid 2012) :thumbup:
Now i use more my pc than my original Mac lol :wtf:
Here are the Screenshots:
https://plus.google.com/u/0/111132725119539181952/posts/KL6Kbi2AEcH?sfc=true
Last edited by Shaneee on Mon Jan 16, 2017 1:05 pm, edited 1 time in total. Reason: Link Coded.
Shaneee liked this
by: Meta_KnightX
#12388
Great to hear you got a Hackintosh built! :thumbup:
Just out of curiousity, which version of Sierra? 10.12.0,10.12.1, or 10.12.2?
by: Dante_Snake
#12390
Meta_KnightX wrote:Great to hear you got a Hackintosh built! :thumbup:
Hi! thanks, well i try the 10.12.2 but i got a lot of kernels panic, so i try the vanilla version 10.12.0 and is just working fine no kernels panic for now, i hope it helps! cheers :wave:
by: Meta_KnightX
#12412
Thanks! I'm going to try my best to build for 10.12.0. But it's going to be hard on a MacBook on 2006 since a lot of apps don't support 10.6 now these days.
by: Ackados
#12413
Congrats! I know a lot of members here are getting kernel panics still. :P Well done!
by: iceporn007
#14429
What kernel did you use? I can only use 12.12.1 kernel but it had green icon glitch.
by: Ackados
#14464
iceporn007 wrote:What kernel did you use? I can only use 12.12.1 kernel but it had green icon glitch.
He's using Chad's method, of installing 10.12.0, so a slightly older kernel.
by: Bootlymen
#17469
How did you fix the USB 2.0 ? Got only the 3.0 working.
