#55452
Now i´ve my system up and running flawlessly.
I´v build my system very similar to Apophis System. He help me on some questions Thank you mate :thumbup:
Thanks to amd-osx.com and hackintosh-forum.de for all the help!
I´m using this "monster" only for music production in my studio.
This CPU is awesome!
Apophis, amdpush, fibonacci liked this
#55555
Yes no problem but don't look closely cause of my disarranged Music Production Studio at the moment ;-)
Apophis liked this
#55650
@Galve2000, Thunderbolt is working but currently no hot plug. So you have to connect the device before booting the machine up otherwise the controller will not be detected by macOS.
Some other users already confirmed even LGs 5k Thunderbolt display working.
(See viewtopic.php?f=35&t=9843&start=70 for more details)
#55656
Galve2000 wrote:Does this board support Thunderbolt?
Can you post your EFI folder please?
At the moment I´ve much to do (cause of the corona virus) for my business! When I have more time I´ll post my efi.
#55907
Kuleone wrote: Sun Mar 22, 2020 2:11 pm What DAW are you currently using? Does Protools work with your setup? Does Waves bundle work with your set up?
Thank you in advance
I´m using Logic Pro X 10.4.8 and Studio One 4.6.1.
Don´t know about Protools cause I didn't use it.
At the moment I also do not use any Waves Plugins but I want use Waves NLS for Mixing in Logic (in S1 there is "CTC" for summing emulating an Analogue Mixing Console) in near future.
I see no reason why protools shouldn't work.
#55917
TimeActor wrote: Wed Mar 11, 2020 11:26 am Now i´ve my system up and running flawlessly.
Does Thunderbolt-03 Work ? Hot plug work ?
