#55189
First Hackintosh build. I went straight for Open core and never used Clover. Just for the serials numbers used clover configurator.
Open core 5.5 debug
PC Build:
CPU: Ryzen 7 3700x
GPU: Sapphire Nitro+ 5700XT
Motherboard: Asus Rog Strix 470-i
RAM: Corsair DDR4 Vengeance LPX 2x8GB 3200
SSD: Samsung 970 EVO 1TB M.2 SSD
PSU: Corsair RM650
Wifi/Bluetooth chipcard: Swapped the built-in motherboard card with a bcm94352z card. Took me some time to figure out how to get this to work. but ended up just using
Bootloader: OC 5.5
Installed catalina 10.15.3
Installation method: https://khronokernel.github.io/Opencore ... top-Guide/
BIOS: Used the Vanilla Guide setup
See my EFI folder with everything.
Drivers:
XhciDxe.efi
NvmExpressDxe.efi
VBoxHfs.efi
ApfsDriverLoader.efi
AppleUsbKbDxe.efi
FwRuntimeServices.efi
VirtualSmc.efi
Used Kexts:
AppleALC.kext
Lilu.kext
WhateverGreen.kext
SmallTreeIntel82576.kext
FakeSMC.kext
W836x.kext
RadeonMonitor.kext
AmdCPUMonitor.kext
AMD-USB-Map.kext
For network: (important to use the same order in the config.plist as I have done in mine)
AirportBrcmFixup.kext
BrcmFirmwareRepo.kext
BrcmBluetoothInjector.kext
BrcmPatchRAM3.kext
Everything works except for sleep. It just doesn't wake. Would like to know once there is a permanent solution for this.
Took a day or two to learn and make as above. Do not 100% understand all kexts and drivers yet but managed to make everything work. I would appreciate comments if I've used ones that should not be there or if I'm missing anything important.
Shout out to the whole AMD-OSX community & Open core Vanilla guide! Without these would have never even considered building my own Hackintosh.
I see now that AppleALC is not working properly, at the moment cannot adjust volume for output device LG32UK550 monitor nor is any of my motherboard auxiliary in/output showing. EFI file is posted above. Anyone any ideas how to fix?
(4.65 MiB) Downloaded 54 times
