#54945
This is my first build with a Ryzen and first time using Opencore. It took a little bit more searching and tinkering but it is up and running now. I followed the OpenCore vanilla guide and leverage this forum for those times that I got stuck. The only tricky part was during install it would shutdown, found a thread on this forum that suggested to add -wegnoegpu to the boot argument and it worked like a charm.
I have a BRCM94360CS2 installed in a PCI-E adapter so continuity works. So far iMessage and AppleID works fine. Haven't tried power mgmt but that is on the bottom of my list since this a desktop.
Whenzi, kwoods liked this
