#54632
I followed a video on YouTube that didn't even required me to have a Mac. Also did this built after the success of other user who used the same processor and mainboard as me.
The parts I used:
-Ryzen 9 3900X
-ASRock X570M Pro 4 mATX
-16 GB of Gskill Trident Neo 3600MHz PC4-28800
-2 x Sabrent 256GB Rocket NVMe PCIe M.2 2280 (1 for Windows / 1 Mac)
-XFX Rx 5700 XT Raw II 8GB GDDR6 1905MHz
- GMYLE Bluetooth Dongle, Ultra-Mini USB Broadcom BCM20702 Class 2 (works OOB)
-Seagate BarraCuda 2TB Internal Hard Drive HDD - 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache 3.5-Inch
-Corsair CX Series 750 Watt 80
NZXT H510 - Compact ATX Mid-Tower PC Gaming Case
I must note that for the installation I needed to use an RX 560 I took from my wife's computer in order to get into the installer. After the installation deleted the Watevergreen kext and exchange the card for my RX 5700 XT and everything was working flawlessly. It is currently connected to a 144Hz monitor through HDMI.
I must note that first I installed Windows in EFI mode and then I proceeded to install Hackintosh.
*Screenshots attached*
Screen Shot 2020-02-06 at 3.02.37 PM.png (78.27 KiB) Viewed 224 times
