#54432
Hi,
my Ryzentosh is working, except sleep.
Ryzen X3900
ASUS X570P (FW 1405)
Radeon RX560 4 GB Gigabyte
2x16GB G.skill RAM
HW-Monitor working
USB working
Audio working
Ethernet working
Sleep not working
Rest not tested (personal no need for it)
EFI w/o serial
(1.08 MiB) Downloaded 69 times
Bildschirmfoto 2020-02-06 um 13.55.23.png (55.61 KiB) Viewed 394 times
#54587
Here my how to (very short)
Mostly done by this Video from YouTube
Use additional kext: Voodoo & Realtek 8111
https://www.youtube.com/watch?v=l_QPLl81GrY
At first start I got the massage:
"no vault provides"
You have to go to your plist and change Vault from true to false
2. Start: "This version of Mac OS is not supported" - change Mac Pro 5.1 to iMacPro 1,1
3. Start; In Startmenu insert:
keepsyms=1 npci=0x2000 debug=0x100 agdpmod=pikera
4. No Grafik during loading but Catalina works
got o config.plist, uefi , quirks, provide console GOP (change from no to yes)
5. HW sensor: Search for HW Sensors v3r86 For AMD and install needed
6, remove Yellow Icons for HDDs to grey:
Change to yes:
config.plist, kernel, quirks, external disc items
Hope it works for you
Tested today with RX5500XT: Works fine with the same EFI - no changes
Re: Ryzen - X3900 - 32 GB - RX560 or RT 5500 XT - OC 0.5.5 - ASUS X570-P - Catalina 10.15.3
