#52416
I have been eyeing this laptop for a while and just got released
The specs are Ryzen 7 3750h with a AMD RX 5500m
Since this laptop has a dedicated GPU will GPU acceleration finally work in AMD laptops running OSX
#54241
Possibly. The Device ID of the RX 5500M 7340 is indeed included in macOS kexts.
#54348
Hi Shanee...
Would it be possible to help me with the initial settings for installing the System? I tried in several ways, with several modifications to the EFI and reading the forum tutorials, but I couldn't even install the System. I would love to meet this challenge, I bought this laptop exclusively to try to install Hackintosh due to its specifications.
If you need any data related to the laptop I can provide ... I'm just having difficulties with the first installation ... it usually gives an error in the "xpc switch or bootstrap" part and simply restarts.
In my folder below you have all the details of the machine, including the DSDT extraction I performed.
https://drive.google.com/drive/u/0/fold ... FFgAX0kc72
Thank you!
#54358
Access required to the folder.
#54372
Please try with this EFI. What version of Catalina is on your USB? If it's not 10.15.3 then I recommend you remake it with 10.15.3.
(1.51 MiB) Downloaded 68 times
fabiodj2 liked this
#54398
Hi Shaneee thank you for send EFI folder....its working for install MACOS...
Step by step I followed:
1 - Boot with pendrive and install the MACOS Catalina
2 - The laptop restart and continue the install
3 - When try to boot with MACOS installed, the system stop with message:
IOConsoleUsers: gIOScreenLockState 3, hs 0, bs0, now 0, sm 0x0
Detail: Install with Catalina 10.15.2 and your EFI
Now I try install again with Catalina 10.15.3 (download in progress)
Is there anything I can do to continue the boot and not get this error?
Thank you very much!
I try with Catalina 10.15.3 and have same problem.
#54403
Try adding the boot arg -radvesa
