#56752
Hi all,
I'm looking at upgrading (might as well call it "replacing" as only a hard drive, the psu and the gpu will remain) my computer. I'm an app developer and I want to improve my workflow. I also want to be able to develop for Apple without the hassleof having to rent a machine so I was looking into a Hackingtosh dual-boot. I'm currently looking at buying the following system:
  • Ryzen 2700x
  • WD Blue SN550 1TB
  • Crucial Ballistix 16GB Kit (white) (BL2K8G32C16U4W) (on 3200mhz with XMP)
or maybe as I'm not sure I want 16gb or 32gb ram
  • G.Skill DDR4 Trident-Z 2x16GB 3200Mhz (F4-3200C16D-32GTZKW)
  • MSI X470 Gaming Plus Max
I already own a GPU, which is a
  • Radeon R9 390
Will I run into any issues with osx with this build?
I'm not really set on anything from this list so if anyone has any recommendations I'm completely open to it!
