by: ksxi
#56608
Man it's been a while since I've been here
Can someone help with whether this is compatible?
CPU: Ryzen 3900X
MOBO: ASUS TUF X570 PLUS (Non Wifi so I can get a non-intel wifi pcie card)
RAM: Not sure on brand yet but 32GB 3200+Mhz DDR4
GPU: 970 STRIX (Just old one I had, don't judge me lol)
Boot drive for MacOS will be SATA SSD but Windows will be on NVMe M.2 Drive, if that makes a difference
Thank you, glad to see this community grow!
#56610
Sure yeah but your GPU is going to limit you to High Sierra. https://vanilla.amd-osx.com/
by: ksxi
#56612
Got you, what cards are currently supported? I may be willing to buy a new one for the purpose of this
#56613
by: ksxi
#56616
Brill, just had a look - will get an RX580 when I start building the PC - might be a stupid question, but I'm still going to be using 970 on Windows, if I leave both plugged into my motherboard, MacOS should just ignore the 970 right?
