by: bloomdito
#56302
Hello forum,
would someone please be so kind to check the components if they will work, for my new 3D(2D)- Build?
Software i use: Cinema 4D, Redshift, (Octane), After Effects, Premiere Pro, Logos Pro X.
Because there is still no version of Redhift or Octane for Gpu rendering on Metal/AMD-GPU, I first have to work with High Sierra to use my GTX 1080ti.
As soon as Redhift for Metal / AMD I will buy a Radeonxxxx and upgrade the OS.
So here are my questions:
Is the performance of the GTX 1080ti still so bad or are there any better drivers or patches now?
Is the ASUS PRIME X570-PRO a good choice or should I order a Hackintosh friendlier motherboard, what would be ideal (up to 300 euros)?
Components:
CPU is a Ryzen 9 3750x
ASUS PRIME X570-PRO?
GTX 1080ti
Thank you in advance,
Bloom
Ryzen 9 3950x (sorry)
by: gravis
#56335
I can't say anything for the software you intent to use but I can confirm that Asus x570 Prime Pro works with Ryzen 7 3700X in Catalina 10.15.4. I followed vanilla amd guide and make it work in the first try. Gpu is Sapphire RX 5700 XT btw.
by: bloomdito
#56343
Kool Thank You.
