#55649
Hello, I'd like to know if there is possible to get it to work on any OSX, I don't mind if is an old one like Lion or Sierra. I just need to use a specific tool that doesn't work in VM's. Also it does not need to be perfect I just need the USB ports to work and WiFi or Ethernet to work aswell and if I would need to use Clover or Opencore.
Thaanks
