by: Djuby
#55556
Hi,
Should I try to install macOS on my laptop (details in my signature). Thanks in advance.
Best regards.
#55557
I'm afraid not. macOS lacks the support for AMD integrated graphics.
by: Djuby
#55586
Thanks. You saved me a lot of time and headaches.
Best regards.
