by: PatBateman
#55393
Parts collected so far
ASUS Zenith Extreme Alpha
64gb Corsair Vengence LPX 3200 DDR4
Radeon VII XFX GPU
Corsair RMx850 Powersupply
2tb Intel 660P NVME SSD
I'm thinking either 1950X, 2950X or 2970WX (depending on what I can get at the best value.)
Other items will be
Fractal Meshify S2 case
AMD Wraith Ripper cooler
Maybe an old Intel 750 AIC 400 gb card for a Windows boot drive.
What kind of problems can I expect and what can I do to fix them?
I haven't done a hackintosh since a 4790K so I'm very interested to see how much better things are now. Anything you can do to help is so very appreciated!
Cheers,
Joel
