by: J05u
#54811
I have 1 slot available for the GPU, gen4 x4 and i want to buy 5700xt
Can someone please compare speeds it will work as gen 3 or gen 4?
I am asking this because gen4 x4 is like gen3 x8 in speed and it will be enough to unleash all power of 5700xt
by: Apophis
#54843
I had to switch back to Gen 3 since my riser card does not support Gen 4 reliably, but I could boot up MacOS at least once with PCIe 4 and my SSD works well with PCIe 4 under MacOS.
by: J05u
#54844
Apophis wrote:I had to switch back to Gen 3 since my riser card does not support Gen 4 reliably, but I could boot up MacOS at least once with PCIe 4 and my SSD works well with PCIe 4 under MacOS.
Thank you, if gen 4 working my plan will also work:) but if no, i am dead :D
by: Apophis
#54845
J05u wrote:Thank you, if gen 4 working my plan will also work:) but if no, i am dead :D
I cannot confirm if it is working reliably though, maybe someone else with an X570 board and a Navi card can confirm this?
Many guides recommend setting Gen 3 for the graphics card, and the Navi drivers are known to be rather buggy at the moment.
