#54563
So i got this very little, but powerfull STX Box and its breathtaking:
ASRock Deskmini A300 Barebone (A300 STX Mainboard) Link: http://asrock.com/nettop/AMD/DeskMini%2 ... /index.asp
AMD Ryzen 3400G with Radeon Vega 11
2x8 GB G.Skill RipJaws DDR4 3000 SO-DIMM CL16
Crucial P1 500GB m.2 PCIE SSD NVME
It has NO dedicated GPU (its not possible because of the extra tiny size).
This little box is amazing, but - of course - it would be more amazing, if it could run OSX :)
I'm pretty new to Ryzentosh and i did read, that it is only possible with a DEDICATED GPU, not with the integrated ones in AMD's APU's. But i am not really shure, so i'm asking here :)
So Question #1: Is it Possible? (Yes/No)
Question #1: If yes, HOW? :D I would need a starting point.
