by: onelazymofo
#5583
Hello,
I have a system with AMD Phenom 1100T X6 up and running, thanks to the USB image by Shanee. I have everything (wifi, ethernet, sound) working except for graphics. I have tried modifying the kexts to recognize my graphics card ID without luck; anyone in here have better luck with this card: ATI FirePro v4800?
Thanks
Edit: Well, got it working :thumbup:
I am not sure what I did differently, I updated the AMD5000Controller.kext/Info.plist file to include the device ID 0x68c81002
Screen Shot 2016-08-14 at 2.23.04 PM.png (3.28 MiB) Viewed 409 times
BUT
it is laggy, any fix for this?
Edit 2:
Lads! I have it working with full acceleration now :D
Turns out I needed to update the AMDRadeonX3000.kext with the device specifications as well. The FirePro v4800 is a derivative of the Redwood GPU and one has to update the corresponding <key> in the kext.
The systems seems pretty stable so far, I will be duplicating the same system on another partition next.
Cheers!
by: letrain
#42819
I know you posted a while ago but this really helped with my v4800 gpu passthrough. video works great. however I can't get audio to work. so I'm wondering how you got that to work for you?
