#42746
I would use clover but apparently it doesn't like AMD. Enoch seems to be the best option as that is what boots El Capitan (my CPU doesn't support SSE4.1) but it will not cooperate with Windows 10.
Full error:
An operating system wasn't found. Try disconnecting any drives that don't contain an operating system. Press Ctrl+Alt+Del to restart
Any help is appreciated!
I've got a very similar x570 Taichi & 3950x se[…]
@iGPU , This is awesome, thanks! Your EFI confi[…]
thanks for sharing your file. I was struggling for[…]
https://imgur.com/a/Xf9q25f Specs: \[CPU\] \[[…]
