#4326
Did you even read the top of the website dude?????
"Note: FX Users will face small graphical glitches. A fix is being investigated. More info here"
Not that hard to read and there is no fix yet.
#4346
The "If you know what you're doing" refers to developers if they are willing to help.
We are working on fixing this issue and I will post the fix when we get it.
#10264
LiiionSODMG wrote:Is there a fix already? because i have the same problem
Please, be patience. Shaneee said you they're investigating and working on fixing this issue. If they manage to fix the problem, they'll post it as soon as possible.
#23795
You know I had this problem on Sierra and chads config file for clover actually FIXED it, maybe there's something in it that would work for el capitan as well, process or boot-arg wise?
#23905
There's no fix for that on FX/APU on El Capitan.
